Thread: Water balance problems
    Two weeks I have been battling balance issues and a slight pale green algae on bottom of pool.
    Here are my numbers:
    Tc 4.6
    FC 4.3
    Cc .3
    Ph 6.8
    TA 100
    CYA 80
    Put in filter aid and ph up, now my PH is 7.5 & TC is 4.5 today, other numbers the same.
    Filter pressure has risen slightly, maybe not enough to be concerned with.
    Water hazy but no green I can really see.
    Help please!
    AG 24' ( Columbia PL30-6 sand filter), 2hp 2 sp pump, cholorine, Tennessee
    Taylor k- 2006 test kit
    Re: Water balance problems
    Hhhhhhhhhhhh
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    If you have algae, you need to perform the Shock Level And Maintain process.
    With CYA at 80, that means FC needs to be waaaaay up there at 31.
    That's the only way to get ahead of the algae growth and get it killed off for keeps. And it's not just taking it to 31 FC one time; it might need a few days to complete the process. Follow the SLAM instructions completely.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Unless you have a SWG, what went wrong is that at a CYA level of 80 you needed to keep at a very minimum 6ppm FC to prevent algae and to kill organics and bacteria in your pool water and it's recommended you actually target keeping it at 9ppm as the daily maintenance level. That 6 is just the MINIMUM !!
    Under 6 and things start growing and the green tint is bad but it's the stuff you don't see in there I'd be more worried about if you share that pool with others.
    See the table for your CYA here - - > http://www.troublefreepool.com/conte...art-slam-shock
    You need to SLAM (shock) the pool to get rid of the "green" as mentioned by Richard above in the link.
    It would be good to also drain off some water to dilute that CYA level down to something more reasonable in the 30-50 range before you SLAM so it's financially more reasonable in the amount of bleach you'll use.
    If you are presently using a bag shock for chlorine it could be why your CYA is so high. We recommend you use liquid bleach to chlorinate the pool as it doesn't contain anything else and leaves your CYA level stable.
    Solar Blanket, Well Water, Borax Added. 68
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What test kit are using to get your results ?
    Jeff
