I have not seen any patterns whatsoever, but the little guys seems to get most everything clean.
when it decides to change direction it's suppose to jump 90 degrees and that's what the floater add/remove adjustment is for.
I guess if he jumps only 45 degrees there would be a different 'pattern'?
I added the third floater and wedged a fourth on the opposite side and it's zooming all over the place now. I guess the added buoyancy helps it get around easier. Thanks
