Results 1 to 7 of 7
Thread: anthony pool light obsolete - suitable replacement?
    Mar 2010
    Dallas, TX
    61
    so my parents just purchased a home that their pool needed some work. We are finally down to the light and I ordered a pentair amerlite, thinking doesn't get any more standard than than. But when it came in we soon realized the bottom mounting point is different on the amerlite. The anthony pool light has a pin like mount vs the amerlite is a step lip.
    I know we aren't the first ones to replace an anthony light, any members have history with this problem? BTW I wasn't able to see if the light had any kind of model number or anything it was so corroded.
    anthony ring vs amerlite ring
    Mar 2010
    Dallas, TX
    61
    Re: anthony pool light obsolete - suitable replacement?
    anyone?
    Oct 2012
    Houston, TX
    29
    you may be able to get your amerilight to work using a "pool light wedge"
    40,000 gallon ig gunite, Pentair Challanger Century Centurion 2.2 HP Pump, FNS 60 DE filter, Polaris 280, Century Centurion 3/4 HP Booster Pump, Attached ig spa - 1HP Centurion pump - Dual non functioning blowers
    Mar 2010
    Dallas, TX
    61
    thanks for the reply heavyzee, what is the wedge for? and is it something I could buy at leslies?
    Quote Originally Posted by heavyzee View Post
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    The wedge is to secure the new light into the niche which is the part built in the wall.
    Most likely, the replacemetn light may not fit the old anthony one perfectly... the wedge is a nice easy fix to secure the new light into a "mis-matched" niche or if the little threaded tab is stripped out or broken off.
    Leslies prolly carries them. You can google and find out for sure though.
    Divin Dave,
    Jul 2014
    Milpitas, CA
    1
    Quote Originally Posted by heyitsme06 View Post
    anyone?
    The following links may help you to find compatible old Anthony ring.
    Pool light 120V 500 Watt - R40 - Swimming Pool
    The original Swimquip Pool Light. Millions installed all over the world, The Sta-Rite fits most old Anthony pools underwater lights. Light measures 8-1/2" outside dimensions. (1960-1990)
    http://www.sunplay.com/Pentair-SwimQ...05086-0025.htm
    http://www.poolcenter.com/p/the-orig...uip-pool-light
    http://www.inyopools.com/pool_parts_...ool_light.aspx
    Sep 2016
    Katonah NY
    169
    Hi - I am going through something similar now with my Anthony pool. Were you able to figure out what to do for a light replacement?
    40k IG Gunite pool (47x21), Jandy iQ904-PS, Pentair 011018 VS Pump, Pentair 180009 FNS Plus Filter, Pentair 261152 Multiport
    Stenner Liquid Chlorine Dispenser - 30 gallon tank, Zodiac PB4-60 Polaris Booster Pump, Polaris 280 Pool cleaner
    Pool School + Test Kit + PoolMath = A TROUBLE FREE POOL Become a TFP Supporter!
