Hey Brad,
Should be BradisGlad!
Anyway, I'm doing the same thing you did. Did you use "3 kits" of the foam or did you mean 3 pairs of tubes? I'm ordering mine and want to know.
Also, I see why you stuck with only one box of the Torque Loc - expensive. I'll do the same combo as you, TorqueLoc and carbon staples/w injection, and that will also seal the inside of the crack.
Did you know they have epoxy to inject in the crack as well as foam. If so, why did you choose foam? I have a question in to Brad at Anderson on which one to use.
Did you consider/find Emecole when you bought the Anderson Leakmaster stuff? I wonder how they compare.
The big question is, did you cut that pine tree down yourself???!!
And of course, how is the pool holding up? You do have moister soil than I have down south of you so I hope it's not settling on you but if it has I wonder how your fixes are holding together.
Good job! and great pic of you and Leslie in the pool
Jim
