Results 1 to 9 of 9
Thread: The stand pipe is too high
    Jul 2014
    Winnipeg
    6
    I was removing the head on my pool filter and I managed to pull the stand pipe up. Do I have to empty the filter? Can I reuse the sand that's in there? It's a Sta Rite T240 BP1.
    38,301
    Re: The stand pipe is too high
    Yes you are going to have to vacuum out the filter and get the laterals and pipe reset (inspect for damage). You can reuse the sand if it is not clumped up ... a good opportunity to rinse/clean the sand while it is out.
    Jul 2014
    Winnipeg
    6
    Thank you, in this case does all the sand need to come out or will the laterals go down far enough with some still in the bottom?
    38,301
    I have no idea, but guessing that nearly all of it needs to come out since I think the laterals sit on the bottom.
    Jul 2014
    Winnipeg
    6
    That's fair, I should have asked about the vacuum. Do you mean a conventional wet/dry shop vac?
    38,301
    Yes, that is the only way I can think or to easily remove the sand.
    Jul 2014
    Winnipeg
    6
    The sand is wet so I'm scooping it out by hand, I've got the stand pipe and laterals out. I can't find any reference to cleaning sand when it's not in the filter, any suggestions?
    38,301
    put it in a bucket and run a hose through it so any gunk spills out ... same as the Deep Cleaning your Sand Filter process.
    Jul 2014
    Winnipeg
    6
    Thank you
