Thread: Rain
    Jul 2014
    Old Bridge, NJ
    3
    Rain
    I am a new pool owner and just started using bleach to chlorinate my pool. I know you should shock the pool after heavy swimming. Should I use bleach and "slam" the pool or use actual power plus shock for this?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,193
    Re: Rain
    Quote Originally Posted by j_obru View Post
    Following our methods you should NEVER need to shock your pool.
    Test, maintain proper FC levels ans enjoy the pool.
    Sorry, but back to Pool School for you.
    Where are my manners, welcome to TFP!!
    Support the site
    Apr 2010
    Central NJ
    227
    Re: Rain
    When I expect heavy swimming I raise my ppm by 2 over the target, so that it doesn't go below the minimum after the swimming is done.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Rain
    Unlike some, I have manners . . . Welcome to the forum
    +1 good advise and also the one about raising up the chlorine level before a swim party or if you know you'll have a heavier swimmer load than normal.
    Do you have a test kit yet ??
    If you read some of the pool school articles you will understand. Using the method here not only gives you sparkling clear water it does it for a lot less $$$ than using "try this" pool store advise and their spendy chemicals.
    "POOL SCHOOL" is also available in the upper right of the screen. It has it's own button !!
    Quote Originally Posted by tim5055 View Post
    Solar Blanket, Well Water, Borax Added. 68
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Rain
    If you read this thread he was using Leslie's Power Plus too. Well, before he saw the TFP light !!
    http://www.troublefreepool.com/threa...high-CYA-no-FC
