Thread: Hi-jacked thread moved - bob22
    Sep 2008
    Philadelphia
    43
    Quote Originally Posted by JasonLion View Post
    Yes, it is possible to put in too much, but it has to be several times too much before anything undesirable happens.
    What might those happenings be? I am going through a similar situation.
    25,000 gallon
    16' x32' Rectangle IG, Vinyl liner
    DE filter
    Re: Me vs. Iron stains - Round 4
    I used 5 bottles of MM in my 27K gallon pool and the stains haven't reappeared. I also keep my ph around 7.5-7.6
    It does say that MM will remove the metals from water if the correct procedure is followed. I still use the maintenance dose to be safe.
    27K Gallon vinyl pool, 1hp 2 speed Hayward Super Pump, EC-75 DE filter, Stenner 45MPH22 liquid chlorine injection pump with timer control. Taylor K-2006 test kit, Aquabot pool cleaner. location SC PA.
