I bought a bottle of strips but when my 2 SWCG came in, I found they each came with a bottle. So, I had 3 bottles.
To start my salt water pool, I put in 720 lbs of salt. The SWCG's were both saying "lo" but I decided to give them time to get to steady state. After 24 hours, one read "lo" and the other "normal". They were at opposite ends of the pool, each near a return, as instructed. I tested with the strips. I tested many times from strips from each bottle. I did not put them in 1" of water (The bottle didn't say to do that. I checked and now see it says "
For complete instructions, see package insert".) The strips were put in the water for 10 minutes & I got a reading of 2200 ppm. So I go buy more salt and dumped in more 320 lbs, waited 24 hours and then got a then reading of 2600 ppm. I tested many times from strips from each bottle. Now one SWCG read "hi" and the other "normal". I think they're not calibrated properly.
Frantic, I found the Taylor kit and when it arrived, my salt level was 4600 ppm! Too high! So, I'm going to have to dump some water & replace but at least now I can get an accurate reading.
Since I used strips from all 3 bottles, I don't think I got a bad batch. I'll try testing in 1" of water but it seems that would be printed on the bottle if was that important. I mean who reads the inserts?
But out of curiosity I'll do it to see if that makes any difference. But I'll stick with the Taylor Salt testing kit, thank you!
The good news is that after running the SWCG for 7 days, my chlorine was at 7.4 so now I've put the SWCG's on 50% output. Other than the strips messing me up, I am very happy with the SWCG set up...
As for not being allowed to post links? Never heard that rule... I don't see the harm showing people where to get test kits that I like.
Thanks for your input. Have a swimming day.
