Thread: Can you use the tfpc method on indoor pools?
    Jun 2013
    Southeastern British Columbia
    79
    I was reading that indoor pools use less chlorine and also that they have different needs because they don't get direct sunlight. I am wondering if you can still use the tfpc method.
    13 x 24' x52" ultra frame pool (still in the box)
    Going to be set in 2.5' hole with deck at rail height sourounding entirely
    Cartridge filter ( we will see how that goes for one season)
    Natural gas heater and solar cover
    Plan to use bbb method! Yay!!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Can you use the tfpc method on indoor pools?
    Quote Originally Posted by kshuf View Post
    Yes, you sure can. One big change is the CYA recommendation is about 20.
    You can find more info on indoor pools in Chem 201
    You're done SLAMing when:
    Jun 2013
    79
    Thank you
    In addition to the CYA target being 20, the other big difference is that you are far more likely to have issues with CC. Depending on your bather load, in an indoor pool you may well want to use MPS regularly or add a UV system or an ozone system to keep CC under control. Just about everything else is the same.
