Thread: bleach % on pool calculator....
    Jun 2013
    Newcastle, Oklahoma
    508
    I usually set it to 8.25%, because that is the bleach i use (Great Value from Walmart) However, I just noticed on the bottle under the 8.25% it actually says: "Yields 7.86% free chlorine."
    do I put in 8.25 or 7.86? does the pool calculator account for the yield or does it assume the % put in is the yield?
    thanks!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jun 2014
    Lincoln Park, NJ
    29
    Re: bleach % on pool calculator....
    I've been told to use the 8.25% for pool calcs.
    Pool: 19K IG, Vinyl, grecian
    Equipment: Hayward Super Pump (1hp), Cartridge Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by EJ257Turbo View Post
    Yep ^^^^
    You're done SLAMing when:
