Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: Another pump/filter sizing question !!
    Jul 2014
    STILLWATER,NY
    47
    New to the forum....been lurking a whit....great wealth of info here.
    I am having a pool installed in a few weeks....27ft AG and need filter pump advice.
    I currently have 2 pumps ....1 Pentair Superflo model # sf-n1-1a 1 hp pump and a hayward powerflo 1 hp.
    I ran sand with my last pool and want to upgrade to a cartridge filter...reading various threads on different sites I see the common advice is "bigger is better".
    taking that into consideration I have a line on a few different filters at a reasonable price and wonder opinions as to what pump and what filter I should use.
    The first filter is a Hayward c2030 225sq. ft cartridge.
    The 2nd is a Jandy CL580 580 sq. ft cartridge filter.
    Big difference I know......I have a friend with a 16x32 IG and uses a 150 sq ft cartridge filter and his water is beautiful....I always thought it was to small but....
    I will run 2" hard line for the plumbing to help with flow.
    Any opinions or advice is greatly appreciated.
    18,500 AG, VINYL..27' ROUND.. HAYWARD 24" SAND FILTER W/ HAYWARD 1 HP POWERFLO.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Another pump/filter sizing question !!
    Welcome to the forum!
    225 should be sufficient but do yourself a favor and put in a bypass for opening because opening with a cartridge can be PITA.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    Bypass for vacuuming to waste..? I did consider that..thanks.
    If i go with the Jandy ...is it overkill...will the pentair still push enough water?
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    The maximum flow rate for the Pentair is 225 GPM so more than enough. even the APSP-15 rate is 84 GPM and I doubt either of those pumps can produce that much flow rate on AG plumbing so you are safe there too.
    It wouldn't hurt to go with the bigger filter but it probably wouldn't help much either. With only 3-4 months per year of operation, you probably don't need the 225 sq-ft either. I am pretty sure you will be able to go all season without cleaning.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    What is the minimum size filter you would recommend for an 18,500 gallon AG pool?
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Which pump are your using for the filter?
    Mark
    Jul 2014
    STILLWATER,NY
    47
    I plan on using the Pentair superflo..
    mas985's Avatar
    Pleasanton, CA
    11,737
    Ok with that one, you would need at least a 150 sq-ft.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    Ok...thanks....any preference on filters ?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I would just go with Hayward c2030 you mentioned above. It is larger than you "need" but that is ok.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    Missed out on the Hayward....looking at Waterway Proclean 200 sq ft single cartridge ....any thoughts good or bad?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I don't know anything about that filter but Waterway makes fairly decent equipment.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    If I decide to stick with sand...will my Hayward s210t be sufficient paired with the pentair superflo for my 18k gal pool.
    After researching cartridge filters and the cost of replacement filters...sand is looking better to me everyday.
    mas985's Avatar
    Pleasanton, CA
    11,737
    With the SuperFlo, ideally you would want a bigger filter > 3.7 sq-ft or a 270.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    270...meaning a 27" ?? I thought the s210t I have now would be to small.
    Thanks for the help
    mas985's Avatar
    Pleasanton, CA
    11,737
    270 is 27" and yes, the 21" is technically a little too small for the pump but it may work just fine until you are trying to filter out very small debris.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    Found a great deal on a Hayward 24" Pro series....would this suffice or will I eventually want a 27" filter.??
    Appreciate all the help
    mas985's Avatar
    Pleasanton, CA
    11,737
    24" would be ok.
    Mark
    Jul 2014
    STILLWATER,NY
    47
    Thank You !!
  20. Back To Top    #20
    Jul 2014
    STILLWATER,NY
    47
    will the Pentair superlo be to powerful for the 24" filter..? Looking at the specs the pump max flow is about 20gpm more than the pump.
    This is all new to me so I want to make the right decision...
    thanks for answering my "newb" questions.
    Until now I would have used any filter/pump combo without a second thought.
    Almost forgot....should I plumb this with 1 1/2 or 2"..? I have 1 skimmer/return...27ft round AG.
