Results 1 to 11 of 11
Thread: Keep shocking?
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    Keep shocking?
    Last night at midnight my CL/FC ws 23.5ppm I just tested and got 21ppm. Just to clarify, do I need to keep shocking again tonite until the FC change is only 1ppm?
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: Keep shocking?
    The way I understand it from all the reading on here is....
    Keep shocking until your CC is 0.5 or less.
    For me shock level would be around 14 ppm FC or CL
    YMMV
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Mar 2008
    Evans, GA
    323
    Re: Keep shocking?
    Quote Originally Posted by Crzyfrlss1
    YMMV
    My CC is less than 0.5 when I add the R-0003 stuff in doing the CL/dt, water remains clear. I am also not sure of my CYA level. Last check it was 30ppm, so I added CYA to bring it to 50ppm. So my shock level for CYA level of 30 would be about 12 and for 50 it would be about 20. A little over where I am at now. But I suppose I would rather be a tad over than under. Pool looks a lot better this morning. A little cloudy, but the green is gone from under the steps.
    *~ Laura ~*
    TF-100 Test Kit
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: Keep shocking?
    Quote Originally Posted by lulupalooza
    YMMV
    I guess that means you're done shocking.....for now 8)
    Thank you TFP
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Keep shocking?
    You should shock, but verify your CYA test number, and then shock to the appropriate target, no reason to overshoot and put in extra bleach, costing you more money. (Are you out of CYA reagent?) But yeah, that's a 2.5 loss overnight, so shock again tonight and test again in the morning.
    Mar 2008
    Evans, GA
    323
    Re: Keep shocking?
    Quote Originally Posted by frustratedpoolmom
    I have enough CYA regent for 1 more test. I just ordered some more from Dave last night, so hopefully it will get here quick. At 30 CYA it told me to add 46 oz of stabilizer, to get to 50ppm but I only added 32 oz. to make sure I didn't overshoot. I'll test it tomorrow morning and see where it's at.
    *~ Laura ~*
    TF-100 Test Kit
    11,969
    Re: Keep shocking?
    I don't think it will register that fast...usually takes several days to completely dissolve and register fully on the tests...
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Keep shocking?
    Laura,
    Chem geek says we are done shocking when we meet these three criteria:
    The process is complete when:
    A. You hold FC loss to 1.0 or less overnite
    B. Your CC's test .5 or less
    C. Your water is sparkling
    You know, we BBBer's are really into 'C' 8)
    You're done SLAMing when:
    Mar 2008
    Evans, GA
    323
    Re: Keep shocking?
    Thanks for all the help everyone! Pool is looking much better. Almost back to normal, so I hope this last "shock" tonite will do the trick.
    Last question. At what level of CL ppm is it safe for the kids to go swimming??
    *~ Laura ~*
    TF-100 Test Kit
    11,969
    Mar 2008
    Evans, GA
    323
    Re: Keep shocking?
    We just had a knock out pour down rain.. Just tested the CL levels and they are at 12.5 and CC .5 should I go ahead and add more bleach or think I would be ok to wait and shock tomorrow night since we are having a pool party all day tomorrow with a bunch of kids? Pool isn't sparkly clear, but much better.
    *~ Laura ~*
    TF-100 Test Kit
