Thread: Any ideas for soaking taller cartridges?
    Feb 2008
    Los Gatos, CA
    128
    Any ideas for soaking taller cartridges? What container do you soak them in?
    Re: How to clean a cartridge filter
    This is what I use to soak all 4 in at the same time.
    My filters are 25.5" tall so they all just fit.
    Feb 2008
    Los Gatos, CA
    128
    Mine are much taller--32 1/16" Did you post a picture of what you use?
    Salinda
    owner of ~37,000 gallon plaster IG pool/spa combo. Intelliflo VS+ filter pump, 2 hp whisperflo spa jet pump, Jandy Aqualink RS-6 with iAqualink upgrade, The Pool Cleaner 4x suction cleaner, Clean & Clear Plus 520 cartridge filter, Zodiac Clearwater LM2-40 SWG, Sta-rite 400k heater, solar heat pads and coils, Solar-Breeze NX.
    Rick H's Avatar
    Jan 2013
    Liverpool, NY
    45
    My filter is about 30 " tall. I bought one of those plastic storage bins with the cover that was about 32 " long. The filter fits in there no problem, and the cover is nice to keep kids out of it. Only thing is that it is heavy with all that water/cleaning solution in it, but works great.
    Upstate/Central New York. Roman style IG fiberglass pool, 13X33, 8800 gallons, installed July 2012. Pentair cartridge filter, 1 hp Pentair single speed pump. Taylor K2006 Test kit. Went BBB route in spring of 2013, no problems, no regrets!!!!!!
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Any ideas for soaking taller cartridges?
    A Large Plastic Trash Can works pretty well. It does not have to be dedicated to this use either. Just put a liner in and add your solution/water. Close it up and give them a good soak.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
