Thread: how do my numbers look
    Apr 2014
    monroe WI
    11
    using tf-100
    06/28/2014
    PH 7.2
    CH 225
    FC 4ppm
    CC 0
    TA 280
    CYA - 25
    Water Temp - 78*
    CYA is low but it has only been 4 days
    got the first swim in today. What a blast.
    Should I increase the PH a little???
    Jeremiah Strese Southwest WI
    22' x 52" Intex AG 11400 gals (I guess)
    2650 intex sand filter TF-100 test kit
    Hopefully adding water by June 24 2014
    May 2013
    Bay City, Michigan
    283
    Re: how do my numbers look
    You should not raise the PH, at least not with chemicals. You could aerate to bring it up and with your TA that high, your PH will likely rise on it's own over time . Hope you have Muratic acid on stand by.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Apr 2014
    monroe WI
    11
    Quote Originally Posted by scott.MI View Post
    yes have a gallon on hand.
    With your TA that high, I would recommend keeping the pH in the 7.2 to 7.4 range until the TA comes down quite a bit to prevent possible scaling.
    Support the site
    Jul 2011
    phoenix
    133
    Just did a test 3 hours ago.
    FC 4.5
    Ph 7.5
    Ta 70
    Cya 60 (need to increase it a bit
    Cc .5
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
    Iciee, why are you posting your readings?
    Support the site
