Results 1 to 7 of 7
Thread: Need help upgrading pool light from Fiber to LED.
    I'm installing a Fiberstars (Fiber to LED conversion) and wanted to know if I needed to drain water level below light? I'm replacing the existing fiberoptic light with a PAL Treo LED.
    D
    Aug 2011
    Middle TN
    83
    Re: Need help upgrading pool light from Fiber to LED.
    I don't know anything about Fiberstar Fiber. Does it have a niche or how is the PAL treo going in?
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
    Mar 2015
    Harvey, LA
    300
    I know this is an old thread, but I just did the same thing Cracker Shack did, and I wanted to comment here so others can search about it. I bought a PT-6000 to replace my 6004 fiber system. The fiber system lenses screw into dedicated return fittings for the lights. I removed the lenses, then attached a pull wire to the fiber after removing the end fittings on the end of the fiber in the pool.
    After that, I pulled the fiber up through the base out of the pool, then attached the treo led lights to the pull wire and brought them through the base.
    Wiring is a snap, though I do have a problem with the remote---it doesn't work unless I'm right on top of the podium. I read the troubleshooting guide and found the antenna has a 12 foot cord, so I pulled it out of the podium, but still only works if the remote is a foot from the antenna. Either the antenna or the remote has an issue, and I'll deal with it this week. The lights screw in the same way the old lenses did, and has multiple colored escutcheons to match whatever color fittings you have. Very doable as a DIY project.
    To his original question, the instructions say to have the water below the fitting, though the only reason I see this is required is so that you don't leave water in the conduit. It is likely more important in northern climates where water in that conduit could freeze, but here in Louisiana it's not a big deal. I did do the swap while the pool was empty though, taking advantage of the pool being drained by the plaster crew. If I had to do the retrofit with the water in it, I think removing the fiber and attaching pull wire would be very difficult, to the point that I'd consider just pulling the fiber and using a fish tape instead in that scenario. I also applied Teflon tape to the threads of the LEDs, but it doesn't call for it and probably isn't necessary.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Jul 2012
    Cypress TX
    2
    Gilbee, Is there a big difference in the brightness of the new lights. I want to replace my fiber as well, but I'm concerned the new lights won't be much of an improvement.
    Thanks
    Mar 2015
    Harvey, LA
    300
    I didn't see the fiber lights in their original glory (we bought the house a few months ago), and since I don't have water in the pool yet, I can't say for sure, but just based on how they light up the empty pool, I suspect they will be a huge improvement. I had three fiber light bundles in the pool, and a kit with the transformer and three led lights from the company that made the fiber lights (fiberstars/sr smith retrofit is a direct replacement for their old fiber kits) cost just over $900. I was blown away by how expensive the LED lights are, and from what I can tell, I got off cheap.
    Mar 2015
    Harvey, LA
    300
    Here's a pic of my new LEDs
    Jul 2012
    Cypress TX
    2
    Nice, thanks gilbee
    18000 gallon above ground free form w/Dark pebble sheen. Detached raised hot tub, natural rock waterfall. Polaris 3900 cleaner. DE Filter. Jandy Aqualink RS8. TF100 test kit.
