Results 1 to 8 of 8
Thread: Can I add borates during SLAM?
    May 2014
    Tampa, FL
    5
    Is it ok to add borates while SLAMing the pool?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: So you want to add borates to your pool--Why and How
    I don't recommend it. Most ways to add borates also affect pH, and since you can't measure pH during a slam you wouldn't be able to monitor this. Also, borates is considered an optional improvement to water feel with minor algae inhibiting properties. It is not a panacea, and will not help with your SLAM. The single most important thing you ca do to prevent algae is maintaining continuous FC above minimum for CYA level.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    May 2014
    Tampa, FL
    5
    I waited till after the FC levels came down and did the borates. Between coming off of a slam and adding the borates, the water looks amazing. Also the original problem I was chasing of the swg not keeping up on chlorine has been eliminated. My chlorine demand is low enough that I have to run the swg under 50%.
    38,514
    Re: Can I add borates during SLAM?
    I hope your TA was appropriate before you add the borates.
    May 2014
    Tampa, FL
    5
    What's that?
    38,514
    The point of borates is to slow the pH rise. So you need the TA lowered first. If the TA is high, then the pH is going to want to rise and with borates it will be more difficult to lower it. That is why step 1 of the borates process is lowering the TA.
    May 2014
    Tampa, FL
    5
    I was being sarcastic. I followed to process outlined in the borate guide on this site.
    38,514
    So instead of replying with a confirmation, you wasted my time ... I see.
