Thread: Rust On Ladder
    Jul 2013
    Long Island New York
    63
    Rust On Ladder
    I have noticed my ladder seems to be getting what looks like rust developing on it. Also have what appears to be two minor rust stains on liner in the pool. My chemistry is spot on, any suggestions?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Rust On Ladder
    What is your chlorine source?
    Got a pic of the stains?
    What are test results?
    You're done SLAMing when:
    Jul 2013
    63
    Re: Rust On Ladder
    I am a new convert, so this year chlorine source is bleach. I cant even begin to tell you the problems I had last year. I did test results this morning here they are...
    FC-12
    CC-0
    TA-100
    PH-7.8 (although since my FC is high I suspect that is a little off)
    CH-350
    CYA-100
    I will pull the ladder maybe later today after work and post some pics. The stain on the liner will be difficult to photograph will see what i can do
