My SLAM Journey
Do you have time to do more than that? Once when you get home ... And again every hour until you go to bed?
Once when you get out of bed and again on the way out the door to work.
One at a 2 am wake up alarm?
If CL is below 10 after I added all the chemical add MA?
What is being said is that if your FC is 10 or higher, the pH reading will not be accurate. Since you need to be maintaining a SLAM level of 20+ FC, you can probably forget about getting an acurate pH reading for now until the SLAM is done. Just keep SLAMming. The more frequently you can test and adjust FC, the better.
It doesn't look bad in the pix but it got darker and darker as the evening went on (before sundown)
Currents test results:
Ph: still 8.2+
FC: 25.5
Added 4 c MA per karma biker at 9 pm currently 10:22 pm tested 20 min ago
