Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: My Old Intex vs New Polygroup Pro Pool
    Jun 2013
    Seguin TX
    192
    Just wanted to show some differences in the Intex vs Polygroup Pro series of pools for those of you who are curious.
    I will keep this album updated so you can see the progress of the install. Wish me luck.
    Here you can see the new horizontal beam on the left and the orig Intex beam on the right, even though it is smaller in circumference it is a heavier grade of steel than the Intex.
    Top view.
    Water Level
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Jun 2012
    Long Island, NY
    102
    Re: My Old Intex vs New Polygroup Pro Pool
    They almost look like the same type of pool.
    Thanks - John
    Pool: Sharkline Matrix 18 Round 54 Deep
    Pool Size: ~8200 Gallons
    Filter Type: Sand
    Pump: Intex 2650
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Love your water level....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2013
    Seguin TX
    192
    Yes the water level is very "Redneck" as we say in Texas, but this thing is accurate I cant see the hump in the ground that my other half can, but with this thing it is clear I had a 4 inch rise on one side of the dig, we are slowly knocking it down with a Tiller about an inch at a time until we get it all within an inch of level.
    Then we will have the "crusher run" brought in and actually level that.
    Casey's Avatar
    SW PA
    10,421
    Good luck unkyjoe! If you could post the pics to the forum, that would be great! They are so small on the link you provided. Thanks.
    Jun 2013
    Seguin TX
    192
    So my neighbor saw me dealing with the hole and suggested I wet the ground, it serves to make it easier to dig, and since water seeks its own level it shows me exactly where the high and low points are in the circle.
    Funny how you get caught up in doing something and dont remember the most basic things
    Casey's Avatar
    SW PA
    10,421
    I hate leveling and it's the most important job!
    Jun 2013
    Seguin TX
    192
    Ordered 4 cu yards of the 3/4 crusher run with fines and it was delivered yesterday.
    This is the pile.
    Spreading it out.
    View from the deck, now to spread it all out, level it, tamp it... repeat
    Jul 2012
    Seymour, In
    49
    Looks like you are off to a good start! Keep it going and don't forget to keep adding pictures. Everyone loves to see the builds in progress.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Jun 2013
    Seguin TX
    192
    Not much new to report, I can only go outside after 7:30pm to level the base materials, and then can only work an hour at a time, I have managed to level the circumfrence of the pool so far and it is spot on, now to drag more material into the middle of the spot and level this with the outside edges to make a smooth and level bottom for the pool. This stuff when compacted is like cement and I am glad I went this route as it is much easier to manage that the native soil. Wednesday my Rhino pad will be here and we should be able to put the pool up then. I will post pics once all the leveling is done.
    Jun 2013
    Seguin TX
    192
    It's level baby!
    Level in the middle as well.
    Ground cloth laid out and liner ready to be installed.
    Liner and rails laid out, ready to install the legs.
    Pool is up, my other half is spreading out the wrinkles.
    Filling the pool.
    One post is about 1/4 inch out of level, other than that this thing is spot on, now to wait for it to fill, install the skimmer, pump, and return, balance the chems and ready to swim. If I can do it so can you!
    Casey's Avatar
    SW PA
    10,421
    AWESOME! Great job UnkyJoe!!! You did it! Hope you enjoy the pool!!!
    Jun 2013
    Seguin TX
    192
    Greetings again, year 2 of my polygroup pool, the time spent leveling and using the material I did for a base paid off, pool is still level, I left it up over the short winter we have here in South Texas, it was a green swamp, but that is due to the filter finally biting the dust.
    I ordered a new pump and filter, the Intex 2800GPH unit with a 14" filter, a little smaller than my hayward filter but it still should do the job.
    I also bought a hyaward auqa bug pool cleaner. I am tired of vacumming the pool.
    I will get back on my chemical care once the new pump arrives tommarow.
    Please learn this lesson, make sure the pool base is setup properly, it is time consuming but will pay off years down the road.
    Jun 2013
    Seguin TX
    192
    While I was typing the previous message FedEx delivered my pump. Off to work I go.
    Feb 2013
    Yukon, Oklahoma
    220
    I have to ask, is the liner noticably better than the standard Intex you replaced this with? I am at year 3 with my 14' Ultra set up her just outside of Oklahoma City. I keep mine covered unless it is being used so I don't have to clean much.
    Bob
    Jun 2013
    Seguin TX
    192
    The liners seem to be the same quality between the pool I have now "Summer Escapes" and the Intex I had that blew over in the wind after emptying it.
    I actually thought we bought another Intex pool, but when we got it home I knew better, it all worked out as I like this one better.
    Just got my pump and filter all hooked up and started the SLAM process to kill whatever is living in it, I went from green to cloudy blue even with the bad filter before it gave up, now I am blue and cloudy.
    Jun 2012
    MA
    347
    So this post is called Intex vs poly group pool. Is the only difference the heavier grade of steel in the posts?
    Apr 2014
    FOUR cORNERS
    111
    awesome job, looks great, I am getting ready to put solar and reconnect piping this weekend!!!! yaaaaaa
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Jun 2013
    Seguin TX
    192
    That and it comes with a Skimmer, if you look on the net people complain about the build quality of the PolyGroup "also called Summer Escapes" but I actually think the frame on this one is more sound, and so does my neighbor, he is a welder and says the steel on the PolyGroup is quite a bit thicker than the old Intex I had, you can compare the posts and the PolyGroup is heavier. Time will tell on this, but it has been up nearly a year and no leaks or seam issues. I have a feeling those complaining did not go to the trouble to make sure their pools were level.
  20. Back To Top    #20
    Apr 2015
    LA
    2
    I have this exact pool and the pump is a POS, I bought the index sand/salt combo. I need help with hooking it up! I bought the adaptor that goes where old impeller style pump goes but new intex sand filter system it is all threaded much bigger hoses!
    My kids do not understand this problem!! thanks
