Yes. Are the hoses connected properly? If you try filtering with the flow going backwards, air will get trapped and the sand will get all disturbed and possibly blow back into the pool. Double check that. The ports are probably labelled. Just make sure the hose from the pump goes to the filter inlet.plumbed backwards?
