Thread: TA Question
    May 2014
    MILLSTONE TOWNSHIP, NJ
    87
    TA Question
    Just finished SLAM process...should I do something with TA or let it "settle" for awhile first and then retest...per Pool Math my overall CSI is -0.01 and pool is sparkling clear!
    FC 20
    CC 0-0.5
    CYA 40-50
    CH 250
    TA 130
    ph 7.5
    Thx!!
    33,000 gals, DE, IG, plaster, Purex Triton FNSP 60 filter, Pentair Super Flo 2hp, Pentair MinMax Heater
    Re: TA Question
    If your PH goes up annoyingly quickly, you should lower TA. Otherwise, just lower the PH to 7.2 any time it gets up to 7.8 and don't worry about TA unless it gets to the bottom of the recommended range (which seems unlikely).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: TA Question
    Agreed, if you have to fight pH rise, work it down slowly with consistent acid doses.
    Essential Links:
    May 2014
    87
    Re: TA Question
    Thx all!!
