Results 1 to 9 of 9
Thread: Poured too much acid in. PH is now ~6.8. SHould I let it right itself?
    Mar 2013
    Baltimore, MD
    30
    It was creeping to the ~7.8 range and I added too much acid and now I'm around 6.8. Should I be concerned or should I let it right itself?
    1988 installed, 45,500 Gal, IG, Gunite w/spa
    60 sqft DE Filter, Pentair WhisperFlo 2 HP WF-28 pump, "Shasta" infloor cleaner.
    Re: Poured too much acid in. PH is now ~6.8. SHould I let it right itself?
    Since the PH test shows any PH below 6.8 as 6.8, it is best to raise the PH right away until you get it to at least 7.0.
    Low PH can damage the pool/equipment. If the PH is really 6.8 the issue is very minor, but if you went way over it could be fairly significant.
    Mar 2013
    Baltimore, MD
    30
    I keep reading conflicting opinions on how to raise it. Whats the best way?
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Fast?.......20 mule team borax.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2013
    Baltimore, MD
    30
    Is this stuff super concentration? How much should I start with?
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Pool Math
    Click on that link and enter your information regarding your pool. Then scroll down to the pH section and place your target # and your current #. Mouse over the information bar and it will tell you how much to add. Take it in steps tho, no need to overshoot and raise it too high.
    And you can get 20 Mule Team in the laundry isle.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    How much muriatic acid did you add and what was your TA before adding the acid?
    What strength was the acid?
    Support the site
    Mar 2013
    Baltimore, MD
    30
    Ph is now reading 7.2. Thanks for your help!!
