Thread: Intex liner design. ....why do they do this?
    Ok...sencond year with our 14x42. I didn't noticed last year.....maybe because the liner was new and "tight" ....and/or maybe the liner hadn't been stretched out???
    Anyhow the bottom seam around the inside perimeter, the flap is up. So this holds dirt, etc., Seems like they would have designed the seam where the flap would fold downwards vs upwards?
    Anyone else have this problem?
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    Jun 2012
    Central Alabama
    55
    Re: Intex liner design. ....why do they do this?
    Same problem here. Ours holds a ton of dirt. I get in the pool with a vacuum hose a a regular house vacuum brush attachment and vacuum it up. It's a headache though.
    Intex Ultra 16x48
    Intex 2650 Sand Filter
    Installed June 2, 2012
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Same here and ours isn't an intex pool, but a pro series and it isn't any different. It would be so much nicer if it was the other way around though.
    The regular house hold vacuum brush attachment is an excellent idea.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    That's what I've been doing....I get in and snorkel with the vacuum hose. (No end on hose)
    I don't mind doing it every couole weeks...but is kinda a pain.
    Two Hayward I lets
    Florida/Alabama
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yup I had a seam like that on my Bestway pool (rectangle pool like intex), I vacuumed my pool everyday specifically because of that seam, and I live in an area with heaps of dust....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
