Results 1 to 12 of 12
Thread: Adding MA safely
    simste01's Avatar
    May 2014
    Huntington, IN
    21
    Adding MA safely
    In another thread I read, "Lower the bottle into the water (keep the opening a few inches above the water) and slowly pour that way. I see some vapors, just make sure the wind is blowing away from you. "
    How do you measure the amount you are adding when pouring directly from the bottle? Or is a guessed approximate amount okay?
    14'x28', 11.7K gal, IG, vinyl. Automatic pool cover, 1hp Hayward single speed pump, Hayward sand filter, Hayward heat pump, Hayward Navigator, TF-100 test kit w/ SpeedStir, Intellichlor IC15 SWG
    Jan 2013
    Houston, TX
    1,079
    Adding MA safely
    I measure mine out into a plastic cup that has been labeled acid with marks on the side at 16, 24 and 30 oz.
    Then pour gently in front of a return with the pump on high.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    simste01's Avatar
    May 2014
    Huntington, IN
    21
    Re: Adding MA safely
    I've been pouring MA into a 2 quart plastic measuring cup and slowly pouring the measured amount in front of the deep end return. But when I read "Lower the bottle into the water" I thought that would be a lot easier and safer, but how to measure pouring directly from the bottle?
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I think people that use this method just eyeball it. If you have to add a quart that's 1/4 bottle.
    I personally use a measuring cup and dilute into a 5 gallon bucket of pool water. Some here have said that this technique add more steps, and thus more exposure, but I find I get less fumes as I am not pouring slowly for a long period of time.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    30,431
    Yeah, the larger the pool you have, the more you can "eyeball" the amount. I am able to do that in my pool (43k) but it would be a somewhat trickier (and overdose prone) in a 5k pool.
    You just have to work out a common sense solution that best fits your comfort level.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My favorite is in my spa when Pool Math tells me to add 1.7 ounces... drip drip drip, done.
    Isolated Spa - 345 Gallons
    Jan 2013
    Houston, TX
    1,079
    Quote Originally Posted by JVTrain View Post
    I'm visualizing ...
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    So your wrist is calibrated, three drips = 1.7 ounces? Kinda reminds me of the "butt-dyno" in the motor-sports performance world.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by svenpup View Post
    haha. butt-dyno.
    let's put it this way. pH was about 8-8.1, pool math called for 1.1 ounces (just checked what I actually did) to get to 7.2. After 3 drips and 20 minutes of circulating the pH was 7.2. Some would call it lucky (my wife) but I say I'm calibrated.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I pre dilute. I measure my acid very carefully, then pour it into a half full five gallon bucket of pool water and then pour that in. It's not necessary, and maybe obsessive, but that's the way I do it.
    Essential Links:
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I used pool math to figure out how much acid it takes to lower PH 0.1, in my case it's about 16 oz or 1 red solo cup. 7.8, 4 solo cups to get it down to 7.4. It's close enough, I also have a 2 quart Rubbermaid pitcher I use. Also always pour with yourself standing up wind. Seeing the "smoke" is interesting in hot humid Florida.
    jjslinger's Avatar
    Sep 2011
    Santa Rosa, CA
    97
    Quote Originally Posted by bobodaclown View Post
    I noticed your pool was about the same volume as mine, yet I know it takes less than half that amount to lower my pH by 0.1; I was very perplexed, messing around with PoolMath, then aha! You must have borates in your pool.
    Anyway, I'm one of those who just "eyeballs" it and pours directly from the bottle into the pool in order to minimize handling the MA. I have practiced with water, and I'm pretty "calibrated" as to what 1 cup is.
    16K gal IG 16'x28' pebble since 2011; Pentair Easytouch; Sta-Rite Intellipro VS pump; Sta-Rite 400 sq. ft. cartridge (System 3); 6 Heliocol Solar Panels; Aquamatic Cover; Legend pressure-side cleaner with Hayward booster pump; TF100 Test Kit.
