Results 1 to 11 of 11
Thread: K-2005 replacement reagents
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    folks, I need to buy refills for my k-2005 kit. Checked Tftestkits.com but they don't have refills for K-2005. Can I use K-2006 refills?
    I need R-0001, R-0002, R-0004, R0009, R0012.
    Thanks
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Re: K-2005 replacement reagents
    I ended up ordering directly from Taylor.
    Here's the link for anyone else with k-2005 who needs refills.
    http://taylortechnologies.com/produc...&SearchString=
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    The reagents in the two kits are the same, if they're numbered the same. They're all Taylor. You could have ordered the FAS-DPD tester and turned your K-2005 into a K-2006. Sorry I didn't see this thread yesterday.
    38,299
    The tests and reagents are the same for the K2006 and K2005. With the exception of the chlorine test which you should upgrade anyway.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Thanks guys... wish I knew yesterday.... well its done now. Next year when order more will do you as you suggest.
    38,299
    You still should order the FAS-DPD reagents.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    FAS-DPD are chlorine, right?
    38,299
    You have a DPD chlorine test (pink matching colors), which has some big limitations. The K-2006 comes with the FAS-DPD chlorine test instead which is FAR superior. All the other tests are identical between the K2005 and K2006.
    Add the FAS-DPD to your kit and you will have the equivalent to the K-2006 (with the extra DPD test you have now which is pretty useless).
    BTW, you can order the FAS-DPD test from tftestkits as the reagents are the same between the K-2006 and the TF-100 .. they are just different qu
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    I see, thanks for the explanation. one more q. with FAS-DPD, do you I also need a different measuring vile. or the one I have with k2005 works?
    38,299
    As long as you can measure 10ml in your current vial, then you are fine ... although it may be easier to swirl with a separate one. The FAS-DPD kit comes with the 2 reagents, a vial, and a little scooper. If you just buy the reagents, you should be able to use any vial and then just a little Popsicle stick or something for the scooper.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    understood. thank you Jason.
