Thread: Temporary Pool Pump?
    May 2014
    United States
    12
    So it is going to take 2-3 weeks to get my replacement parts for my pump.
    What can I do to rig up something temporary until then?
    Pool is starting to need cleaning.
    I have a sump pump, maybe somehow use that?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Temporary Pool Pump?
    It won't help you vacuum or filter, but a sump pump and a hose at the far end of the pool will help keep the chemicals mixed. So will brushing. If you hunt down a wall whale brush, you'll be amazed at how much water they can move. And how easy you can bend an aluminum pole with it set to max lift.
