Thread: Hayward 3/4 superpump.. bearings going bad? Fix yourself?
    I have a 7 yr old 3/4 HP that's making noise. It's just basically the same noise it's made since new, but 5 times louder.
    Can I get the bearings I need locally???
    Is it worth it to fix?
    Re: Hayward 3/4 superpump.. bearings going bad? Fix yourself?
    It is certainly possible to get bearings and to replace them yourself, but it is fairly complex to do so. There aren't generally handy cross references to lookup the part number, so you usually have to remove the old ones and then find something that matches. One good option is to take the motor to a motor rebuild shop, which should exist locally.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Here is a great resource: http://wetheadpumprepair.com/
    Mark
    Quote Originally Posted by mas985 View Post
    I just purchased 2 new bearings, shaft seal and a bearing puller from www.wetheadpumprepair.com
    Their customer service is awesome and they stand behind what they sell. I checked into this, and wanted to be sure I was getting quality bearings and parts, and their reputation is great. Will report back.
    Here is the noise my 8 yr old pump is making, the 6203 bearings.:
    http://www.youtube.com/watch?v=_M_2Kpuq_xY
    buddywiser's Avatar
    Morgantown, WV
    98
    Jason B, how did this go? It's my turn to do this.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
