Results 1 to 13 of 13
Thread: New Bleach dispenser
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    Cool New Bleach dispenser
    Here is a pick of my new bleach dispenser my hubby made me. It works great!!
    AG 24' round 52" walls, 12,900 gal
    Proline 22" sand filter, Proline 1hp pump, vinyl liner, Taylor TF-100 test kit, TFPC
    38,262
    Re: New Bleach dispenser
    I assume there is a hole in the lid or something?
    I am not convinced how well this will actually work since the rate of the bleach coming out will be variable depending on how full the bottle is.
    May 2013
    North East Ohio
    959
    I bet the idea is they put in the bottle what the dose is and this just drips it our over say an hour, etc.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Looks like a makeshift funnel. Bottom of jug is cut out right? So you measure what you need and then add to the funnel? With a very small hole that probably works well. Too slow adding is fine, too fast would be not so fine.
    Isolated Spa - 345 Gallons
    38,262
    Ah, I see ... does look more like a funnel. As long as it is draining over the return, that should work pretty well.
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    Yes. Cap has a tiny hole drilled in it.
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    @jbizzle. It is in front if the return. And it pour out a lot slower than I have the patience to do by hand lol.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    I'd paint that sucker black to keep the precious liquid protected from the sun, at least until it can join with the sworn defender of chlorine... CYA!
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    Good idea Jesse! But it only had bleach in it once the sun has gone down.
    Suggestion: Temporarily replace the drilled cap with one that doesn't have a hole. Then add water, one cup (or quart) at a time, and put black marks on the sides of the jug at the water line for each addition.
    With the volume markings, you can be very accurate with your chlorine additions without having to use a separate measuring cup.
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    Cool. A bleach dribbler.
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    4myBitsy's Avatar
    May 2013
    Milford, CT
    37
    Great idea Tom. That wAs part of the plan. 😉
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    That's awful close to the side of that liner.
