Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: slamming pool
    Jul 2010
    Mount Carmel, Illinois
    35
    slamming pool
    when slamming pool do I stabilize at the same time?
    Pool Size - 6000 gallons
    Filter - Cartridge
    Above Ground Pool
    38,475
    Re: slamming pool
    You should set your stabilizer first so you know what FC level is required for the SLAM. See the FC/CYA Chart.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: slamming pool
    Quote Originally Posted by Gerri View Post
    You can. But you need to know what your target CYA is - what that CYA you've added should raise it to - so you can use the appropriate level FC for your CYA.
    Tell us a little more. What's going on? What does the water look like? What are your test results? Why are you SLAMming?
    Jul 2010
    35
    Re: slamming pool
    The water looks like a milky greenish blue. Cannot see the bottom.
    FC 0
    CC .5
    PH 7.8
    T/A 210
    CYA I am assuming none cause the black dot was visible when tube was completely filled
    I have gotten the PH level down to 7.4
    If you need anymore info just let me know.
    Filter - Cartridge
    Above Ground Pool
    38,475
    Re: slamming pool
    So add 20-30ppm of stabilizer and then SLAM away.
    Jul 2010
    35
    Re: slamming pool
    ok but what is meant by ppm is that meaning set my goal number to that I feel so dumb.
    Filter - Cartridge
    Above Ground Pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: slamming pool
    ppm means... parts per million. Set your goal to 20-30.
    Jeff
    Jul 2010
    35
    Re: slamming pool
    ok thank you i kind of thought that is what you meant
    Filter - Cartridge
    Above Ground Pool
    Richard320's Avatar
    Jan 2010
    19,051
    Re: slamming pool
    Stabilizer is CYA aka Cyanuric Acid. You buy it at the pool store, or walmart, or the pool section at a big box hardware store. For a pool your size, you only need 1 lbs to get to 30 parts per million. Dry volume = 3 cups. Wash your good measuring cup out well when you're done with it. You pour it in a sock or nylon and tie it shut and drop it in the skimmer or hang it over the edge of the pool in front of the return. It will take a few days to dissolve all the way. That's it.
    Jugs Away!
    Target 12 FC with 30 CYA.
    Jul 2010
    35
    Re: slamming pool
    ok before I asked about slamming and stabilizing at the same time I had already knew what my cya was and knew the appropriate level for FC so I had already added my bleach. I just didn't know if I should stabilize at the same time. So it had been about an hour before when i added the bleach and just checked and now it is reading my FC at 17.5 which when I started about an hour or so ago it was 0. Does that sound ok I just thought that was a big jump and I added exactly the amount it stated
    Filter - Cartridge
    Above Ground Pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: slamming pool
    If your CYA level is 30 your SLAM level is 12. Your pool volume could be off. Did you add the correct strength of chlorine into pool math ? Did you put in the target level of 12 ?
    You'll be ok. It'll come down. 😎
    Jeff
    Jul 2010
    35
    Re: slamming pool
    At the time when I did it I only had my goal set on 10. So since it was 17.5 when I test it again should I add more if it is above 12? The way I was reading on slamming was like I might be adding alot of bleach Just sort of confused. Like I said earlier I feel so dumb.
    Filter - Cartridge
    Above Ground Pool
    Richard320's Avatar
    Jan 2010
    19,051
    Re: slamming pool
    Double check you have all the settings on poolmath right. If the bleach is 12% and the calculator is set for 6%, you'll overdose. Also, if the volume defaulted to 10000, and your pool is only 5000, you'll overdose.
    Relax a little. It's only a pool. Nobody's grading you on this. If FC is less than 12, you need to add. If it's above 12, you don't. Just take a reading and plug it into the now column and set 12 as the target and it will tell you how much to add. Tomorrow, the light bulb will go off and it will all make sense. With pool chemistry, you do a lot of learning by doing. Maybe you're just tired. Forget about it and pick it up again in the morning.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: slamming pool
    And your not dumb. Nobody is born knowing this stuff. You'll get it with time. I promise. Just keep asking questions as the only dumb question is the one NOT asked ! 😎
    Jeff
    Jul 2010
    35
    Re: slamming pool
    lol Thank you all I will post back tomorrow.
    Filter - Cartridge
    Above Ground Pool
    Jul 2010
    35
    Re: slamming pool
    Just tested pool for FC and still 17.5. Vacummed up a lot of milky looking residue of some sort. As cloudy as the pool is (where I can't even see the bottom) when I scoop the water out that I am using to test with (which I do go down to about middle of pool) it is clear.
    Filter - Cartridge
    Above Ground Pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: slamming pool
    What was your CC ?
    Jeff
    Jul 2010
    35
    Re: slamming pool
    It was 0. Also all the stabilizer I put in the sock last nite was 3 cups 1 oz and it is almost completely gone. I read where that might take several days to dissolve. Is that odd? I really appreciate your help Thanks
    Filter - Cartridge
    Above Ground Pool
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    slamming pool
    Sometimes it dissolves fast and sometimes it takes awhile. No problem with how fast or slow it dissolves. It can take up to a week to fully register on a test though. 😎
    Jeff
  20. Back To Top    #20
    Jul 2010
    35
    Re: slamming pool
    ok so with my FC being 17.5 and my CC at 0 don't add anything? And then test again in about 30 minutes or so?
    Filter - Cartridge
    Above Ground Pool
