Thread: hayward ec50a & ec50ac whats the difference
    May 2014
    Ontario, Canada
    2
    I am in the market for a new Hayward de filter (currently using a hayward perflex ec40) I am trying to figure our the difference in these new pumps are. can anyone help please?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: hayward ec50a & ec50ac whats the difference
    As far as I know, the A model has the bolts around the belly where you take the head assembly off while the AC has the clamp/spring assembly in place of the bolts. I believe the shell and clamping method are the only difference and internally are the same. The parts guides are the same.
    I have the EC50AC and it's been an excellent filter and the clamp is quick and easy to remove with a ratcheting 9/16 inch wrench.
    -- Guy --
    patrick3229's Avatar
    Feb 2012
    259
    I prefer the clamp style as sometimes the bolts can rust and make it very difficult to remove the lid. The only other complaint on the Perflex is the DE fingers are really expensive to replace so when it comes time to replace all of the fingers within the filter it is almost as expensive as buying a whole new filter.
    May 2014
    Ontario, Canada
    2
    don't all Hayward de filters have the fingers?
    55,000 litres in ground, vinyl liner.
    Hayward 1.5 h.p super pump
    Hayward EC 40 DE filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    No, only the Perflex series have fingers, the Pro-Grid series does not
    Feb 2012
    259
    The other thing to know is that the Perflex uses a bump handle system to clean the fingers, basically a plate which runs up and down the fingers to clean them. The Pro Grid uses a backwash valve to clean the grids, I personally like Pro Grid much better.
