Thread: Removing Water To Lower CYA
    Jul 2013
    Long Island New York
    63
    What is the best way to remove water to lower my CYA, I have a cover pump that I can use but that would be SLOW. Can I hook a hose up to my backwash port? What would I put my multi-valve to, waste? Thanks in advance.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Removing Water To Lower CYA
    Multivalve to waste will work till the water gets below the skimmer line. Some folks rent submersible pumps. You can start a siphon using a plain old water hose as well. What kind of pool we talking about. Please add a signature line with equipment to your profile.
    Jul 2013
    63
    Sorry about that, I did leave that info out didnt I...
    I have a 16 x 36 rectangular inground vinyl liner pool of about 26,000 gallons with a Hayward DE filter and Hayward pump.
    I can set the suction side to main drain instead of skimmers, that should take care of the problem correct? I have a friend that has a submersible pump as well. Might opt to do that.
    Oct 2013
    Chapin, SC
    1,141
    Close your skimmer valves before the water gets too low. You dont want to be sucking air.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    38,305
    You might be able to get a good bit out if you can isolate the floor ... don't turn off the pump though or you may not get prime back. Keep an eye on it and it you start to get air in the pump basket, you will need to stop and use the submersible.
    Jul 2013
    63
    I didn't think about possibly sucking air. Great point, I will borrow my friends submersible. Thank you!
