Results 1 to 11 of 11
Thread: Quick question....
    Jul 2012
    Forest, VA
    79
    Quick question....
    Is it possible for a pool that gets sunshine from 7am - 7pm to lose 5 ppm FC in one day just due to sun burn off? CYA is currently at 60.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    38,371
    Re: Quick question....
    Depends on how high the FC started, but that does seem a bit high.
    Oct 2013
    Chapin, SC
    1,141
    And on what else may be going on besides sunshine!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,632
    Mine loses 4 and everybody else here seems to think that's high too. But it is what it is. CYA around 50. YMMV.
    Jul 2012
    Forest, VA
    79
    I guess the only way to be sure is to run an OCLT to make sure that I am not losing FC to anything else. If that comes back ok.....I guess it is what it is. Does pH gradually creep up? I usually have to add 1/2 gal of 8.25% clorox and some acid to balance out every day. Do these numbers seem within reason or is something sinister going on?
    38,371
    pH tends to creep up. How fast depends on the amount of aeration and your TA level.
    Jul 2012
    Forest, VA
    79
    OCLT results are in
    I ran an OCLT test last night and I lost 1.5 ppm of FC. So does this definitely mean that I have something in my water? It went from 10 to 8.5
    Also when the solution goes from light pink to clear, do you count the last drop?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: OCLT results are in
    Yes and yes. The drop that turns it from pink to clear counts. The next drop where it stays clear doesn't.
    How does your water look?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You testing the PH after you add the chlorine or before? What sources of aeration are present in your pool?
    Jul 2012
    Forest, VA
    79
    Ok I was not counting the last drop, results are unchanged 21 drops last night, 18 drops this morning. 10.5 to 9.0 FC The water looks spectacular, crystal clear. There are always several (30-40) insects (spiders, rolly polly, worms and earwigs) in the bottom of the pool every day. I vacuum them out every other day. Could I be losing FC to those bugs as well? As far as pH is concerned I test before I add chlorine. Very little aeration....one jet that just breaks the surface. I will try and post a pic.
    Jul 2012
    Forest, VA
    79
