OK, I'm tired of slamming, not really, but I'm getting frustrated. Last 2 days/night FC was at 12 and dropped to 10 after 8 hr morning test.
Today's readings after 14 total gallons of 10% bleach and 1/2 a canister of HTH brand CYA approx. 2lbs, the water I am replenishing with is just normal city tap drinking water (if that matters, I would say 1/2 the pool volume is city water) The cloudiness appears to be murky, but I'm not for sure how to describe it. I let the pool set undisturbed for 10 hours and it doesn't settle out. I am back flushing about every 10-12 hours, going by recommendations of 20 lb increase, it is actually normal at 26lbs and I'm back flushing when it gets close to 40lbs. Am I just being inpatient? Should I add the other 2lbs of CYA - scared to go overboard. But also judging by pH it needs more, should I go the muratic acid route? Any advice would be appreciated even if it is "Quit whining and stay the course!"
FC 12
CC 1
CH 125
TA 240
pH 8.0 litmus test
CYA <20
