Thread: Heat pump and Tigerflex
    May 2014
    NB
    9
    I'm sure this has been covered for years, new and want to confirm, can I use flex from heat pump to the returns?
    What is the ballpark discharge temp of a 50,000BTU air to water heat pump?
    Thanks
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Heat pump and Tigerflex
    I don't think it'll be an issue. If you're feeling conservative, you could use SCH80 PVC (more heat resistant) for a foot or so, then transition to the flex.
    May 2014
    NB
    9
    Thanks, that's the plan..
