Thread: Seepage from paramount system
    Oct 2007
    Indianapolis, Indiana
    23
    Hello,
    We have noticed a very light seepage of water on two of the pipes leading from our paramount system. What can we use to reseal that area? And is that all that we need to do?
    lnmnmns
    40,000 gal IG w/vinyl liner, 300 sq ft cartridge filter, Dura-Glas II pump w/1 hp motor, Heat Siphon heat pump, IntelliChlor swg, Paramount Floor Cleaning System, Automatic Pool Cover
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Seepage from paramount system
    So, the pipes going down from the bottom of the valve, right? Can you tell where the water is coming from? I mean, from the pipe joints, or maybe the gasket up above is leaking and the water dis dribbling down there?
    Oct 2007
    23
    Quote Originally Posted by Melt In The Sun View Post
    Yes...the pipes going down from the bottom of the valve. The water seems to be coming from the pipe joints.
    Sep 2012
    Noblesville, IN
    83
    If I understand what you're saying (and I think I do), each pipe has an O-ring where it comes out of the main valve housing. The O-rings may be going bad. You could swap them around and see if the leaks follow them. A rebuild kit is avilable that has new O-rings and gears for the valve. I just "rebuilt" mine. It didn't work when we bought the house.....it does now!
