Results 1 to 17 of 17
Thread: Question on filer drain plug
    Mark R's Avatar
    Nov 2013
    Desert Southwest, USA
    166
    Installed a new one and wrapped the threads with Teflon tape but still leaks. Is there anything else I can use to stop the drip drip drip.
    Thanks
    Mark
    EDIT: Filter drain plug !!
    12k gal Gunite/Hayward filter C5520BH with quad 33 inch filters. 2.5 hp motor. Pool is on south side, so full sun light. Spill over spa.
    Laar's heater LT250-Low NOx Gas Fired for pool/spa 250,000 BTU. Roof mount 6 panel solar system installed east/south. TF-100 test kit. May-September 100+ degrees out side.
    38,343
    Re: Question on filer drain plug
    I thought most (all?) filter drain plugs used an o-ring so no need for tape.
    Mark R's Avatar
    Nov 2013
    166
    I saw no o ring when I replaced the old one a few months ago. The new one came with out one. What could be my options, the new plug was by its self and the one I replaced had always used tape. Is there some other kind of seal I could use ? Or should I use more tape for a better seal. It's not a lot of water but it's very wasteful and annoying. I would like a solution to stop the minor leak.
    Thank you for the response
    30,426
    Mine has an O-ring as well. The surface on the filter is not perfectly flat on mine so the O-ring is essential.
    If you are out and about today, I would take the plug with me and buy an O-ring to fit and then some pipe dope. Try the O-ring by itself and if that doesn't work, apply the pipe dope in lieu of the teflon tape. One of those ideas should seal it.
    I understand perfectly how annoying those minor leaks are.
    PS - you might be able to find a diagram of parts for your filter and see if it calls for that O-ring.
    Mark R's Avatar
    Nov 2013
    166
    Thanks for your advice guys
    Mark R's Avatar
    Nov 2013
    166
    Here's some pics, pool store said no o ring or gasket needed. I don't usually take their advice at heart. So other then Teflon tape, pipe dope would seal it better and won't lock it in, right ? It does seem to be a very flat area, no curves where the plug goes.
    Thanks
    Sent -3 or -7
    30,426
    1. It looks a little gnarled up like it's been forced open with the wrong tool. The mating surfaces may be damaged
    2. Pipe dope will not set up so you can remove it when you want......it may or may not leak because of the above.
    3. It still looks to me like a gasket is qappropriate
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Mark, are you sure of the model number? I'm finding lots of close numbers, but not that model.
    All the filters that resemble yours list "1-1/2" Drain Plug with O-Ring" on the parts diagrams.
    http://www.a1poolparts.com/-strse-38...ter/Detail.bok
    Mark R's Avatar
    Nov 2013
    166
    I was very careful when installing, I'll go to Lowes and get a gasket and some dope.
    Thank you
    38,343
    Ca you take a picture with the plug out and of the back of the plug?
    Mark R's Avatar
    Nov 2013
    166
    Mine is the one on the right
    Thanks
    Sent -3 or -7
    Mark R's Avatar
    Nov 2013
    166
    Sorry if it's blurry
    I'll get a better pic tomorrow
    Plug pic too
    Sent -3 or -7
    Mark R's Avatar
    Nov 2013
    166
    C5520BH model, the other is C4520BH
    EDIT:
    Seems from the parts link it needs a gasket !
    Sent -3 or -7
    Mark R's Avatar
    Nov 2013
    166
    Cool Re: Question on filer drain plug
    Yes, needs an O-Ring. My fault for not doing due diligence and listening to someone at the pool store
    EDIt: Trouble Free School saves the day. Again..
    Thank you for this wonderful site
    Mark R's Avatar
    Nov 2013
    166
    I know everyone was worried about my 2 drips a minute lol
    I installed O ring with a little lube and presto, all fixed !!
    Richard320's Avatar
    Jan 2010
    19,034
    Quote Originally Posted by Mark R View Post
    Mark R's Avatar
    Nov 2013
    166
    So it's leaking again, I took if off and it has a few hairline cracks in the new plug. Took it back and they gave me another one and installed it finger tight, lubed the O ring and Teflon Tape. Can anyone suggest a better drain plug then these plastics ones that are probably made in China ? With the dry weather and constant sun in the desert I think the plastic ones won't last. I take the drain plug out 3 or 4 times a year to clean the bottom of the filter.
    Thanks
