Thread: digital salt meter
    digital salt meter
    has anyone used a didital salt meter? I see them from $20.00 to over $200.00 and was wondering if the $20 one works as well as the expensive ones
    23,000 gallon in-ground 16'x36' pool, 3.5 to 8 ft deep; Pentair Intelliflo VS+SVRS pump; Sta-rite system3 cartridge filter, Mastertemp 300K Heater, Polaris 280 Cleaner Circupool Si30 chlorine generator . 2 bottom drains, 1 skimmer, 5 returns
    38,514
    Re: digital salt meter
    If the $20 worked as well as the $200 ... who would buy the expensive one
    Just curious why you are thinking of getting one? As long as the SWG is happy, then things are fine. It is good to double check independently, but the cheaper drop based salt test is plenty accurate enough and requires no calibration. Or many people just use the salt strips.
    The electronic meters all drift and need to be re-calibrated frequently, even the expensive ones. If you are measuring salt levels several times a day, that can be worth the effort, but for residential use it isn't.
