Thread: Help! Pool deck drain cover tape
    Mar 2013
    TN
    178
    The tape over the deck drain has been on way too long and coming off in bits and pieces. Is the a solvent or anything else that makes this easier!
    20x49 double roman 3.5' to 8.5 deep', 44,000 gal. SWG, TF-100 test kit with speed stir, concrete walls with vinyl liner, cartridge filter on an IG pool with a 1hp main pump and 1.5hp booster pump. Pool built April 2013
    Re: Help! Pool deck drain cover tape
    You could try Goo Gone. It is good at removing adhesive residue.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    WD 40 and one of those rough dish washing pads.
    Divin Dave,
