Thread: Bleach & Borax?
    Aug 2013
    Hilton Head, SC
    133
    Question Bleach & Borax?
    Baking soda I can find everywhere. Just paid $8 for 12lbs @ Wal-Mart.
    Cannot find 6% bleach. Only "concentrated" 8.25 strength. Can I use that?
    No one seems to have borax. Maybe the mule train doesn't get to SC?
    Any ideas?
    TIA
    Ed
    4k, IG, Gunnite, Jandy Valve, 1HP Haywood, 2" flow, single 2" line for skimming & vacuum, Pentair FNSP 36 DE w/125 GPM Multiport 50 PSI, TF-100 Test Kit, built 1991, Hilton Head, SC
    Feb 2014
    Madison, WI
    8
    Re: Bleach & Borax?
    8.25% is fine as long as it is unscented plain bleach.
    Test kit: TF-100
    Pool: 33K gal 20x40' IG vinyl w/ diving board, waterslide, fiberglass steps. PacFab PF50 stainless steel sand filter. Hayward H250 heater. Polaris 380 with 3/4hp Pentair LA01N booster pump
    Indoor Spa: 400gal...still gathering info about it
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Bleach & Borax?
    Yes, you absolutely can use 8.25% bleach. In fact, you could use higher concentration bleach if you can find it. Use the PoolMath tool to help you with the dosing amounts. As for Borax, availability seems to vary by store and general location. You may not even need Borax. Therefore, I would first determine if you have a need for Borax before going out of your way to search for it. If you do have a need for it, you may want to try Amazon if you cannot find it locally.
    Aug 2013
    Hilton Head, SC
    133
    Re: Bleach & Borax?
    Yep answered my own question in pool school (duh!)
    Wife thinks she found borax at Target.....
    Thx again.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Re: Bleach & Borax?
    Borax you will find in the laundry section of most grocery stores.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    38,251
    Re: Bleach & Borax?
    Hold up here ... why are you buying baking soda and borax? Most pool owners never need either of them. Have you already tested and determined that you need them?
    The TFPC method is really just about understanding your pool’s chemistry and through accurate testing, adding only what the pool NEEDS.
