Thread: Shock level
    schertzy82's Avatar
    May 2012
    Peoria, IL
    100
    Shock level
    Pool school says that shock level for a CYA of 70 is 28, while Pool Calculator says it's 20. Which one is correct?
    Intex 18ft x 52in Ultra Frame Pool, hard plumbed w/skimmer and fountain
    Intex 4000 gph cartridge filter pump
    Intex SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Shock level
    Skip poolcalculator and use Poolmath. It's been updated, and also includes the new 121 oz 8.25% Chlorox in the dosings.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Shock level
    ^^^What he said.
