Thread: Uprights lean left to right
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Exclamation Uprights lean left to right
    Hello
    Some of my pool uprights are leaning left or right. Not much just a little. Can I remove the top rail cap and move them a little when the pool is full of water? Or should I drain it?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Casey's Avatar
    SW PA
    10,432
    Re: Uprights lean left to right
    I used a level for plumb to set mine. You should be able to tap them left or right to straighten them and adjust the metal track that helps hold the liner on. I'm sorry I didn't see this earlier. Are you still filling the pool? Did you make adjustments already?
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by Casey View Post
    We used level to set them up. But it was REALLY windy one day before the pool was filled with water and maybe something moved. Now the pool is full of water. It is not bad. You can't see it the first time, unless you stare at the pool for a while. Now to move them left or right I have to remove the top rim and then tap on the upright? Maybe I can do only 3 at a time?
    Casey's Avatar
    SW PA
    10,432
    Yep.
    Pysiek's Avatar
    Apr 2012
    419
    How about if there are 2 or 3 that lean in or out? Can I tap on them also?
    Casey's Avatar
    SW PA
    10,432
    No, you can not. That is more along the lines of being out of level.
