Thread: Starting up new PebbleSheen
    May 2012
    Arcadia, Ca
    50
    Hi all. We just had our pool re-done with pebble sheen. We filled it and the next day our pool man poured in about half gallon acid! Should I be concerned? (live in So Calif and it's been 100)
    24'x15' 4.5 deep (avg) 13000 gallon pebble bottom in ground playpool
    Cartridge filter with a hayward 2.5hp pump.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Starting up new PebbleSheen re-do and proper levels
    Quote Originally Posted by exbcmc View Post
    A lot of builders do it, but I'm not in the camp of doing hot starts. Your PB should be responsible for handling that procedure, and if he is doing it, there isn't much you can do about it now. He needs to keep you informed of what's happening. I don't like it, but I don't think you need to worry. He is responsible for the finish quality.
    Essential Links:
    Casey's Avatar
    SW PA
    10,427
    And to add to brushpup's post.... you're responsible to follow his guidelines to protect the warranty on the pool if there is one.
    May 2012
    Arcadia, Ca
    50
    Thank you both
