gtnos
Re: Should I just give up? Can
when you do your pH test. do it twice. if you get a different result, then do a third one for two out of three. That pH test is SENSITIVE. one drop too much or if you dont hold the bottle perfectly upside down while dropping and cause a mis-shaped / mis-sized drop, it will throw that test wayyyy off.
still every once in a while, Ill goof that test and get a radical result (usually on the low side) from what I expected.
then ill retest and it will be where i expected it. then ill test once again to verify.
take your time, and do it twice to make sure you didnt goof it.
