Results 1 to 9 of 9
Thread: Help me label my lines
    Apr 2014
    Central Tx
    61
    1- Skimmer 1
    2- Skimmer 2
    3- Main drain?
    4- ???? (It's on the suction side of the pump)
    5- Return
    So I'm only confused about 3 and 4. Could they both be main drains? I can't see the bottom of my pool to see if I even have two.
    23,000 gal, in-ground, plaster with 24" sand filter, 1.5" piping.
    38,262
    Re: Help me label my lines
    I am not sure how we are going to be able to help ... with no access for experimentation.
    It is pretty odd to have 4 suction lines and only 1 return line though. I can not tell what is going on with line 4 in that picture. I almost wonder if line 4 has been re-purposed from a return line to a suction line?
    Could be that 3 is the floor and 4 is a cleaner line.
    All I can do is guess, but I suspect that 4 is for a suction side cleaner.
    There should should only be one pipe coming from dual main drains. They always join up into a single pipe very close to the drains.
    The only way to be sure what is what is to turn things on and off and see what happens. That will be easier to do when the water is cleared up and you can get in the pool.
    Apr 2014
    Central Tx
    61
    Thanks for the responses.
    What exactly is a suction side cleaner? Is this a dedicated line for a vacuum or something?
    The reason I'm asking about the lines is that I attempted to vacuum today for the first time so I had to experiment with the valves to get enough suction to keep the vacuum hose on the skimmer port. It would only stay put with one skimmer (#1) and the main drain (#3) closed, but the vacuum still wasn't moving much on the bottom. I'm wondering if closing #4 will help. Also, when I closed #1 and #3, the pump pressure eventually rose about 5 psi. I didn't know if this was due to the vacuum doing its job or the pump working extra hard with only one line open.
    A suction side cleaner is a dedicated line for a cleaner that goes around vacuuming on it's own, with a hose connecting it to a port on the side of the pool.
    The filter pressure rise is unexpected. Normally when you shut off suction lines the filter pressure falls a little.
    Apr 2014
    Central Tx
    61
    I guess the pressure rise was due to the vacuum doing its job and the sand filter getting dirty. I backwashed and everything returned back to normal.
    Now my task is to find out what #4 does and what the best way to run the vacuum is.
    Apr 2014
    Central Tx
    61
    I just emailed the previous owner and he confirmed that #4 is a suction side cleaner and I have already found the port. The pool still isn't clear so I had to feel around for it but sure enough, it's there. Thanks again for the help guys.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    I have a similar mixing valve on my suction line, what you have labelled 1 and 2. On mine, one side is the skimmers (both of them) and the other side are the main drains. Are you sure each side is just 1 skimmer?
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Apr 2014
    Central Tx
    61
    Quote Originally Posted by steveg_nh View Post
    Yes. 1 and 2 are separate skimmers.
