Results 1 to 7 of 7
Thread: pool water height is lower than when filled
    Feb 2014
    Upstate, NY
    390
    I have a 3 week old IG pool that I filled up to the skimmers. I just noticed the water level is slightly lower than when I started. Is this normal dissipation ??? I don't think I have a leak at this point.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,865
    Re: pool water height is lower than when filled
    How much lower? How much time are you referring to? Wind and evaporation will lower water levels.......depends on where you are and your weather.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Depending on where you are, it could be normal.
    If you could update your profile, there is a spot for location.
    You can try the bucket test, that would tell you for sure if it is just evaporation or a leak.
    Feb 2014
    Upstate, NY
    390
    Thank you for the replies guys. What is the bucket test ??
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,865
    See the Pool School link at the top.....click on "Solving Problems".....then click on "Leak Detection." ..... You do the bucket test to rule out evaporation as a cause for water loss. It may be normal.....depends on your weather.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    If it's been windy, you can easily lose 1/4 to 1/2 inch per day. I do.
    Bucket test is 2nd to the last paragraph http://www.troublefreepool.com/conte...leak-detection
    Feb 2014
    Upstate, NY
    390
    Thanks guys, It has been very windy here.
