Thread: order of chemicals
    order of chemicals
    25K gal. IG, vinyl, pool is 25 yrs, liner is one yr. just open and used TF-100 for first time. all readings are low or zero. what is first step. chlorine is zero, PH is very weak(below6.8) TA is 20, CYA is 80
    30kgal;IG vinyl [20yrs old+];1.5hp Century Centurion pump.Sand filter fm W. Cooper Ind. with Praher multiport valve. Model # TM-12-L. Polaris 280 Vac.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: order of chemicals
    If you post your numbers we can help more, but in general pH first then FC and then everything else, since you have a vinyl pool CH is not a concern, and TA is always last, almost something to do when you get bored
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP Kiml!
    To help you out, please being to spend some time in Pool School. Start with the ABC's first and work on other things from there.
    With a Cya 80, it is very important to understand what different Chlorine sources will add to your pool.
    At present, you would not want to add Trichlor or Dichlor products. The ingredients are listed on the label.
    Essential Links:
    May 2013
    Fort Lauderdale, FL
    423
    To sum it up- Borax to raise PH. Then clorox to get the FC up. Make sure you check the chlorine/CYA chart to see what FC you need at your CYA level. Like mentioned, don't use any more pucks, they add more CYA and you can't get rid of it without draining pool!
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
