Thread: how do you test in the dark
    driver5's Avatar
    May 2013
    Just outside Nashville Tennessee
    34
    simply put, if I don't have time to test at home while there is natural daylight, I want to be able to test in the dark and I will be using a flashlight. Is a flashlight suitable enough to read color change?
    24' Above Ground Vinyl.
    Cartridge Filter ( bullet style )
    Hayward 1.5 pump
    13,500 Gallons
    Taylor 2006c
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: how do you test in the dark
    Get a bottle of pool water and head inside. In fact, I seldom test the water outside by the pool. The majority of the tests are just fine done inside as the only one we suggest being done outside in natural daylight is the CYA test.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Casey's Avatar
    SW PA
    10,423
    lol I use an empty water or clean soda bottle to collect pool water. I'll fill it once with pool water, dump it and fill it again and head inside.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The only test that really needs to be done outdoors on a bright day is the CYA test, which does not need to be done too often (a few times per season typically), so unless you are a vampire this should not be too much of an issue. (No offensive meant to vampires, or as they may prefer to be called people with light sensitivity and alternative dietary requirements). For the rest of the tests do them indoors under good lighting, for the color matching test like pH hold them up to a good white background, a white wall, white appliance door, etc.
    Ike
