Results 1 to 10 of 10
Thread: O ring seal lubrication
    needed recommendation: which is better to lubricate seals in records, valves, etc. - silicone based products or PTFE based products?
    Thanks in advance for your advice!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: O ring seal lubrication
    I wouldn't think there's any difference between the two in pool applications. I think the differences come into play under conditions such as high vacuum and extreme temperatures that aren't present where we apply these products.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    Dont use Vaseline or any petroleum based lube as it will deteriorate the rubber. Its best to use Teflon based lubes like Magic Lube. My supply house carries it and I would imagine most would carry some kind of Teflon based.
    http://www.pondparts.com/Accessories...ube-p-256.html
    18' x 36' IG Vinyl 30K gallon, Hayward 1 1/2 HP pump and DE Filter hardpiped, Aqua Pro 1300 Electric Heat Pump.
    TF100 Test Kit on order !
    Commercial Popcorn machine, sno cone machine and cotton candy machine, lost my red nose.
    I find that silicone lube works much better than Teflon. Teflon gums up and gets sticky.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'm not even sure what I use. I just bought a tube of "Pool Lube" at the pool store a couple years ago. They had a basket full on the counter by the register.
    38,251
    Quote Originally Posted by JamesW View Post
    That is interesting. Based on observation, I am going to have to guess the that "pool lube" I got at the pool store is Teflon based since it seems to get sticky and hard to clean off the o-rings.
    Might have to look for some silicone based lube.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Here's a link to a Magic-Lube sales brochure. They distribute both silicone and PTFE pool lubricants.
    http://www.aladdin1950.com/files/971...Magic_Lube.pdf
    Although they call their PTFE lube "PTFE Based", the PTFE is really a very fine powder that's added to a grease base.
    Willi's Avatar
    Mar 2014
    Florence, KY
    69
    I wondering now if mine is Silicone based because my gaskets are not sticky and dont gum up. It looks and feels like Vaseline.
    BOSS 820 Pool and Spa Lube is a good product at a good price. Magic Lube II (not regular Magic Lube) and Dow Corning’s #111 Silicone lubricant are also good. Teflon based lubes seem to be more common at pool stores. Going online is usually the best option.
    Support the site
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You can get a 4 oz tube of food grade silicone o-ring lube from amazon for about $11 with free shipping
