There is one screw holding in the light. No seal. The fixture comes out as a sealed unit.
This is not true when there is ANY CYA in the water. Anything in the 7s and the chlorine effectiveness is nearly the same. Plus, when the FC > 10ppm you can not accurately test the pH.Some remarks.
The chlorine has a variable efficiency depending of Ph. The efficiency decreases with the increase of Ph so that above 7.8 has very little killing power. The closer you maintain the water to Ph 7.2 the better the chlorine can kill your algae.
