Thread: Recommended Cleaning Products
    Apr 2014
    New Jersey
    4
    New spa owner here. Looking for some advice in terms of products used to clean your tub. Mainly the shell (in between water fills), vinyl cover, filter, etc...
    Thanks in advance!
    2014 Sundance Optima, and a 19k gallon SW puddle.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Recommended Cleaning Products
    Welcome to TFP!
    For the spa shell, try those Clorox wipes (despite the name, they don't have bleach in them), but they work well at removing waterline film and they do provide a good level of disinfection. I use them all around the house. If the waterline film is a bit stubborn, try Mr. Clean Magic Eraser. These products may also work on the vinyl cover. However, not having a vinyl cover, I have no first-hand experience using either product on that. Someone may be along with a better suggestion for cleaning the cover.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    303 on the cover
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
